Whats wrong with your car right now??
  (s)Low Dynamique
Track Rod End
Exhaust Blowing
Hazard Button Broke
Sunroof Leaks
Clutch
Needs A Clean
Chairbags Aren't Wired (Dashboard Lights)
  Saab 93 Aero Wagon
Needs a gearbox oil change
Suspect 5th syncro is going
Clutch release bearing is noisier than ever
Cambelt due very soon
Overrun map doing my nut
Im not driving it often enough
  Clio 182
The only thing that's wrong with my car now is the fact that someone else will soon be owning it :(
  BG 182
After having mine for a month its in the garage for the second time having its gearbox oil topped up. The gearbox needs resealing to stop it leaking allegedly! The service light has just come on - possibly due to low gearbox oil? The airbag light has come on too, and the emissions light comes and goes as it pleases!
I would say its all part of the charm but its getting on my tits tbh lol
JezzaMac
Needs a splitter
foglight bulb
straighten exhaust (sitting off centre)
Exhaust blowing
2 new tyres
Service
Wash
Renault top mount "fix"
Leaking headlight washer
Petrol
Im driving around europe in a month and a half, dont have much time/money to get it all fixed!
markerboy2002
East Of England - Norfolk
  Liquid Yellow 182
For a change.... Nothing is wrong! Having said that I spent last weekend in my garage fixing all the rattles and squeaks :p
  V6 255
Today it's going in for a cambelt and also having a powerlex dogbone mount fitting. Still has a dodgy chinese tyre on the rear but gonna sort that out when I get it back
Crank Seal leak
Inlet cam timing possibly out
Needs a cambelt, aux belt & tensioners
Faulty passenger dipped beam light/wire
Knackered air vents on the centre console
Knackered heater controls
Rust.
Track rod end needs replacing, probably along with a number of other bushes
Torn seat material
Looks like a D-Turbo
Rear beam will need re-conditioning soon.
Handbrake is s**t
Needs a new passenger front indicator
Gearbox is slightly notchy going into 2nd gear quickly (probably the syncro...)
Could do with a new clutch soon
Could do with new engine/gearbox mounts
Lacquer peel
Front windows runners need some lube as they're sticky as hell.
Exhaust is far too boomy - needs some boxes & wadding removing
Still love it though!
Oof, sounds costly ^.
I have no reverse gear and a leaking rear caliper.
It's just the three or four big jobs that are going to hike the price up. The rest might not happen - depending on work during the summer, the running gear might just get thrown into a 205 shell... That's something I'd Love to do and may have the opportunity to do if I'm lucky! Will have to see how things go. I'm really enjoying the 306 at the moment, despite its many flaws :eek:
markerboy2002
  Liquid Yellow 182
Ok.....now somethings up, my cat and exhaust system need replacing. Anyone selling? I've got the cat sorted already
  Abarth 500 Esseesse
Squeaky squeak going down bumpy roads! I've reason to believe it could be my Powerflex ARB bushes need greasing up again...
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Horn not working,
Loose heat shield over back box.
Kerbed wheels (from previous owners)
No sidelights
  LEXUS LS400
Broken front spring, leaking exhaust, worn rear discs, rattling heat shield over exhaust, irritating rattle coming from passenger seat bracket, leaking headlight washer despite fitting a one way valve (the right way round) two weeks ago.
That's enough for now.
MarcB
  Vw Golf
My Car Needs The following
New Battery
Alternator
Aux Belt Kit
Timing Belt
De-Phaser Pulley
Water Pump
Good Service
AST Top Mounts Fitted
Forge Hose Kit Fitted
Just Had some work done to the car.
Poly Bush Bottom Arms
Track Rod Ends
Ball Joints
New Discs & Pads
Refurbished Front Calipers
Strut Brace Fitted
4 weeks after reporting the fault STILL waiting for replacement parts for my BRAND NEW Koni rear dampers,
My Brake light doesn't work on my Cup Spoiler,
Front fog lights don't work,
Drivers seat won't lean forward,
Needs a service.
Typically French really!
  clio 05 van,megane
Rear exhaust mount perished
Diesel needs to be hand bled thru if left overnight but runs & drives ok otherwise???
Tow bar not wired up
Needs new driveshaft boot
  Ph1 172 (titanium)
Front and rear disks shot, pads aswell. Fronts being done Wednesday.
Also only firing on 3.
I will report back in a few days when something else happens
  172
cracked sump,seized rear calliper,centre exhaust mount seen better days,manifold 2 cat kit,no tax,MOT now ran out and drivers seat wont tilt foward
GiT
  Shit little Yaris...
Exhaust that's dissolving. That's all.
Needs a wash too.
  BG182FF
Had mine 6 months and all its due now is a service and a rear shock. In two minds whether to replace the shock or just wait till a set of coilovers comes up for sale
  05 clio dynamique
Ideally could do with a new front bumper. Need a new front grille too. Could do with a respray since it's clearly had a bodge job somewhere along the line.. It could be a seat leon too, but it's not.
