OK not being a big wheel swapper, I need some advice on this. Thinking of putting 17s on but its gonna be tight and dont wanna strain the suspension more than it already is if I can help it.
Now a 205/40/17 tyre will *just* fit I think, but the problem is the wheel width. I want it to be bang on, and centred from the hub just the same as my 6.5x15 wheel at the moment. so surely if I put a wider wheel on (7x17) , with the same offset, Im gonna end up with the rim closer to the inner arch? I was thinking if I go for say a 38mm -40mm offset instead of the standard 35mm, then even though the wheel (and tyre) are roughly an extra cm wider, by increasing the offset of the wheel, Ill counteract this and keep the suspension setup roughly the same, with the same amount of clearance on the inner arch? The outer arch has enough room for the wheel to be pushed out slightly anyway.
Any opinions on this?
