Wheel Bearings!
Car  MINI Cooper S
Getting a typical wheel bearing noise in my car, it comes on at high speed, and more so when i turn left (which means the faulty bearing is on the drivers side of my car?)... the problem is, i cant tell weather it is the front or the back! I have had each wheel jacked up (passenger side too) and spun them by hand, they all sound the same, there is no play in any of the wheels either. I then jacked up one front wheel at a time, started the engine put it in 4th gear and spun one wheel up to 90/100mph in the air, then took it out of gear and turned engine off... both front wheels also sounded fine and sounded the same :|
Any other ways to diagnose which wheel bearing is at fault?
Its a 02 1.4 Clio Dynamique+
Thanksss :D
Danny
Front wheel bearing: £18.35
Rear wheel bearing: £26.98
Think i might go for the rear one as you said they are a common fault.
I am pretty confident in changing as i have done a front wheel bearing before on my old mk1 clio, but never done a rear wheel bearing with drums, can you write a quick guide :D i also have a garage round the corner from me to do any pressing if need be.
Danny
undo centre hub nut
pull off drum
take to garage and say "please sir can you help"
pay them £10
put it back on
done
Got the wheel bearing done :) took hub off, took to garage, they changed for £5, got the rear wheel bearing for £20 in the end so 25 quid for the lot not bad :)
However... i have a problem... now when i brake lightly from speeds of 40mph plus... i get a juddering through the brake pedal, doesnt seem to do it as much from lower speeds, and if i brake heavy it does not do it. Took the drum off again and everything looks ok inside, it didnt do this before i changed the wheel bearing (just the wheel bearing hum noise when cornering). If i am traveling slow, and i use the handbrake to stop, the car seems to brake more and then brake less on every turn of the wheel untill the car stops... Any idea's?
Danny
Oh i changed the rear... and it was the right one :) the humming has gone! just this pissing brake problem now... its obv the rear brakes 2 because it does it with the handbrake...
was there a spacer behind the wheel bearing when you took the drum off??
my front or rear question was aimed at White16V
front or rear?
Front Passenger side.
I can't say I've actually noticed the usual rumbling noise but
a) The might Ben said it was going
b) The knowledgable Mark Fish said it was definitely going when I described the symptoms (bit wandery on the steering, top end bite on the brake pedal gone.)
He also said to reduce my mileage to Zero but that's a bit tricky! :S lol
ahh ok.. no, there was just the bearing and the circlip, and then on the other side like a brass stop that the bearing backs onto and the abs thing...
