wheel nut turns
Matt e
does anyone know the minimum number of turns the wheel nut should turn to be safe
ive fitted spacers and fitted longer studs, im getting 12 complete turns buts theres about 3-4mm left of the nut when done up all the way
theres 18mm thread of the stud engaged with the nut 12 x 1.5 = 18mm
  Astra VXR
rule of thumb is minimum 1.5 times the diameter of the stud/bolt
Theres a guide on Ktec site i think it was, saying desired stud length to size of spacer
bashracing
MSA standard is as Kieran says 1.5 time thread diameter,
safe is anything above the stud diameter really,
@Budgie were you in the F1 side or road car projects ?
