Wheel speed difference & ABS sensor
Car  Clio 182
quick question... i'm planning to get a steel spare for the 182. the wheel i've found has a slightly different rolling diameter so it will turn 1.1% faster than standard. is this difference big enough to throw up an ABS error?
also, is a 15" 2002 clio wheel likelt to have the same bolt pattern as std 182 alloys?
ta
ta
A) dunno - although doubt it
B) I ran a 15" steelie from a billabong on a 172 non cup. Only complaint on the 182 is if it's got cup suspension (and Lows) as the offset may induce rubbing. But standard and it should be ok.
thanks buddy. mine's an unmodified non cup so sounds like i should be ok.
anyone else had (or not had) abs probs with this?
