wheels catching the wheel arches ?
Car  clio sport 172
Ive got 16" 205/45 tyres and the wheels are still catching the car is quite low on adjustable damper suspension, it was on 17s but still catching any ideas other than higher the suspension can only think the offset is wrong ?
Mine did the same after the Bilstein B14's settled, lift if back up mines -20mm front and -15mm rear, running standard Turini 16"wheels and no spacers 1.75 deg neg camber at the front, I still had to modify the bumper bracket with a big hammer for final adjustment, not had a noise since.
Regards Russ....
The cars only on spax psx adjustable dampers, would mean putting coil overs on or standard bit of a pain really and it looks good how it sits
