The big power cable goes straight from the amp to the battery, you should have an amp remote out on your HU, this connects to the remote in ont he amp.
That way the amp only powers up when your HU is on
When the HU goes on it sends 12v through the remote cable, the amp senses the voltage and activates a relay which pulls the big voltage from the main cable direct from your battery, make sure you are using suitable gauge cable 12AWG or simmilar should be fine.
Also make sure you put an appropriate fuse as close to the battery as possible (on the main power feed)
whats the best place to take the power lead through from the engine bay to the cockpit, is there a grommit that i can squeeze it through??
the fuse should be as close to the batt. i have a dodgy fuse holder (on my new wiring kit), doesnt look to safe from water, is this a prob, if its going to be in the engine bay, or should it be just in the cockpit area??
there is a grommet in the passenger footwell that the bonnet release cable runs through, remove this then drill a hole big enough for you power cable, replace the grommet, feed cables through, job done
If you dont replace the grommit you will get a lot of engine noise.. its actually unbelievable just how much noise can come through a tiny hole.
Unfortunaly for the 172 anyway its not as easy as it sounds.. I tried it that way and there seemed to be some kinda box it went into.. or it got stuck somewhere and I couldnt see the cable popping out on the other side..
Typically the front bumper is too low to the ground to get ramps under it. and I lent my trolly jack to my mate at the time so I just left it (for now)
Not if the Fuse burns out, then it just doesnt work. And if your having one of those days, dont make the same mistake i did by strippin out all the stereo before checkin the fuse.
