Where do these pipes go on my 172 engine?
Car  RB 182
Hi.. I'm back with a few questions about piping up my engine.. any help appreciated
nr1 never seen before, even just went and check my engine an i dont have that. might be a ph1 engine? (as mine is ph2 without) OR you have got the wrong throttle body on it?
Nr2 as people above
for nr 3 It feeds into the plastic bend that connects the airbox to the throttle body. Wack a samco elbow on without the oil brether pipe for joinging the airfilter to the throttle body and just wack an oil breather filter on nr 3 hole which will keep oil out of your intake.
thanks.. it's normally on the bottom of the throttle body.. (on a phase 1) probably not normally in view..
With no.2 if that's the brake servo what is this one for (which I've plumbed to the brake servo.. have I done this by mistake :eek: ?
Not 100% sure on this one, if it helps it runs down towards under the rear of the headlight in my cup...
