Where to get wishbones
loggyboy
Heard good things about these making the car feel 'like new'. Excuse the many Qs -
The cars a full fat ph2 172, but heard that cup versions are good for handling by adding some castor, any major draw backs?
Do full fat 172s share wishbones with the rest of the range bar cups? (Where does the 10mm/12mm balljoint bolts come in to things?)
I assume 'motor factor' parts will be standard items, as I cant see anything listed for cup models?
If so how much do Renault charge for cup items, and what are the part numbers I need?
Go renault for the proper spec, bushes etc. The change over date is 09/2002 im sure anything built before that date has less caster, anything after that date has extra castor, apparently so all 182s, all 172 cups and some 172s have extra castor, and only ph1 and early ph2 172s have less castor
Drawback can be arch liner rubbing on the front if lowered
