Where/What Snow Foam to buy and how to use it ? And how to use clay ?
I was thinking of buying snow foam and a karcher gun attachment and start using it when washing my car.
But where is the best place to snow foam is ?
And this may sound silly but how do i use it ?
Do i rinse my car to get off loose crap.
Cover it in snow foam and leave for 5 minutes
Rinse it off
Use my shampoo of choice (Duragloss 901) with my wash mitt and 2 bucket method to wash the car as usual and dry.
Then clay,polish and wax etc as needed.
If i want to Clay my car with the Megs Quik Clay or Megs Smooth Surface Claying Kit.
I know i can use the Quick Detailer you get as a lube.
I have heard i can use shampoo as lube as well, what would the dilution ratio of this be ?
And would the Duragloss shampoo be ok for this ?
And after claying do i wash my car again with Duragloss then dry it again before polishing and waxing it ?
And if i was gonna fit Tar/Glue Remover into this procedure to remove a few tar spots where would it be ?
And would it be ok to use my normal wash mitt and buckets etc after using Tar/Glue Remover on my paint ?
Or would i be better to use an old mitt to wash car after using it ?
Cheers Guys
I got my snow foam and lance from i4Detailing. Not used it yet but excellant service so far! Plus a discount for Cliosporters :)
Snow foam works and clings better to a dry car. Apply the snow foam, let dwell, rinse and then bucket wash.
I would then rinse, use tar remover as needed and then clay using soap and water while the car is still wet. 2-4 of capfuls of car shampoo in a 500ml spray bottle is fine, I also re wet the panel first with a wash mitt. Then I would rewash the car, rinse and dry.
