Which brake pipe bender
  Cayman S, RB 182
Hi,
I'm looking for a pipe bender for making up replacement cunifer brake pipes on my Clio.
What do you guys recommend? Would the plier type be ok?
Cheers,
Neil
RichValver
  Clio 16v/172 daily
I use this myself. Gives pretty neat bends
Dicky Belly 3
Yes that should be spot on. There's a huge huge tip on how to use it too that i've got but it's very incredibly hard to write out.
I can do a video for you if you like unless i'm trying to teach you how to suck eggs.
  Cayman S, RB 182
I've bought one of these now, what's the tip? :)
R3k1355
Would be good.
I f**king hate doing brake lines, but really need to re-line one car.
loggyboy
Did mine by hand and with the tool listed first. Make sure you get it right first time as it work hardens pretty quick and any more than 1 or 2 corrections and you will get stress cracks and kinks.
  A special one.
When I used to make brake pipes on the classic Aston Martins the key is getting the length of pipe straight before you even start to make any bends.
I used to roll the cut length of pipe on a bit of flat wood while tapping it with a rubber mallet, once flat you then could make the bends and flare the ends.
