Which brakes?!?! Help please!!! :)
Car  Clio1.4 RT
can anyone help?
I need to replace the front brake pads and discs on a MK1 1992 1.4 RT, unfortunatly i dont have the car with me as its a prezzie for someone and cant get to it until the weekend, which is when i want to do the work, it appears there are two types of brakes, one that are offset wedge shape the other held by bolts, does anyone know which mine will be???
Lucas Girling probably..check the name on the caliper, pads are the same accross the range..
Failing that, sneak to the haynes manuals in halfords. See if there's an un-wrapped manual for you to scope at your leisure.
The best thing is to get some calieprs and caliper brackets from a 16v 1.8 or WIlliams or Mk2 phase 2 cLio and some bigger 259mm disks and some new pads the stock Mk1 none 1.8 16V or Williams use 239mm disks.
GO to Halfords there only there two sizes of brakes your stock ones arn't the ones the WIlliam/1.8 16V and Mk2 phase 2 cars use)
