Which Disks?
Car  Phase 2 172 Cup
would like to replace the disks on the Cup with some grooved, or drilled and grooved
can anyone recommend me a set, circa £100 or so
seen afew on ebay, and iv used one of the sellers before for drilled and grooved (mtec) and want to knwo if anyone has other options
Chris
Stocks on a cup arn't that good imo, so I went out and paid the extra for Brembo max discs with Mintex 1144 fats road/race pads....never looked back and well worth paying the extra!
brembo max discs either plain or grooved
gsfcarparts.com are hard to beat on price as they'll have a local branch to save on postage
jesus I dont know how you lot cook your brakes so easily on the road! Crazy Fools!!
brembo max disks will be fine but it depends on what pads you are going to use as some of the aggressive track pads will destroy them in 2 seconds flat i have tyred them and brembo high carbon disks tbh there is hardly any difference in them just the price and some groves
i got standard they are fine! can get cooked on a tsisty lane if youre really hiking on though! just dont want real bite as it proved killer in my old saxo in the wet
ive got brembo max front disks and they are impressive, Using green stuff pads (a lot here dont like them) but i dont do that many track days, 1 or 2 a year so they are fine, a bit better than standard but dont give out half as much dust as standard (which is the main reason i went for them, how gay! lol)
dont bother with drilled disks they just crack.
2 seconds flat! Yeah ok mate!!
Fair enough you have max discs, but if your doing track days then why are you using greenstuff pads for track days, their not a track day pad iirc?
I had drilled discs on the front from K tec racing for around 18 months and not one bit of crackage! I have also still got drilled on the back and had them on at the same time as the front ones went on and still they are not cracked.
well i dont meant 2 seconds flat but i have done a set in 1000 miles and two track days
Using Brembo Max items currently. Again from e-bay at £90 delivered.:)
Not too sure if DS 2500's should be used with them though.
Can you tell me which of the following will fit a 2005 05 plate Clio 1.6 16v Dynamique (mark two phase three I think that is)?
Discs front and back with standard callipers:
R60116F​
BRAKE DISC-BREMBO'MAX'
CLIO 1.2 16V/1.4 16V 99>
32.00 ​
Add ​
R60116F​
CLIO 1.8 16V
32.00 ​
Add ​
And also pads for the same car:
R64221​
BRAKE PAD SET-GIRLING CAL
CLIO GIRLING
17.50 ​
Add ​
TTMDB1628X​
BRAKE PAD SET-MINTEX XTREME
CLIO GIRLING
38.30 ​
Add ​
R64221AG​
BRAKE PAD SET-EBC GREENST
CLIO GIRLING
36.50 ​
Add ​
Anyone know if these are genuine parts? seems very very cheap!
Like i say i only do one or 2 track days a year if that, and ive found greenstuff to be fine on track as long as its not long sessions, and fine for hard fast road use.
if im doing a long track day i usually just stick a different set of pads on it.
greenstuff were fine on track on my 1.2 16v but that wasnt as heavy or going as fast
Possibly just my experiance though although ive heard of plenty of sports/super car owners changing drilled disks for non drilled disks because of cracking, usually with factory brembos.
sorry to hijack but where would you buy the mintex 1144 pads from ?
any part numbers for the brembo max grooved discs from GSF ?
thanks
