Which part do I need....?
Car  a black one
This is becoming a nightmare!
Yesterday discovered my TRE are gone.
renault cant order the part unless I know what rack i have.
Two different TRE's to choose from??
Anybody help with this? Its doing my head in, no one seems to be able to help from the suppliers!!
been over this before ;) (this maybe for a 172, it was a while ago)
drivers side
JTEKT 7701474493 £39.26+vat
KOYO 7701474493 £39.26+vat
SMI 7701474493 £39.26+vat
TRW 7701047813 £42.26+vat
passenger side
JTEKT 7701474492 £39.26+vat
KOYO 7701474492 £39.26+vat
SMI 7701474492 £39.26+vat
TRW 7701047812 £42.26+vat
so from the above we can conclude that there's 4 different racks, 3 of which use the same rod ends
so technically you have 2 rod ends to choose from, TRW or the other 3 (all the same part number)
for actual track rods
Driver
JTKET 7701473656 £42.26+vat
KOYO 7701473656 £42.26+vat
SMI 7701473656 £42.26+vat
TRW 7701472735 £42.26+vat
Passenger
TRW 7701472734 £42.26+vat
so same again, 3 all the same, TRW different
under the car, above the dogbone, on the rack is a big white sticker, it will say on there
Thanks Fred, will check later.
Whats the main difference between the two track rod ends?
Is there an obvious way to distinguish from the end itself? Mine are female for example?
Marc
Okay cheers Fred,
One last question...
If you shop around you can pick a TRE for about £15. Renault charge £45ish. Is better to pay the dosh and get the reno one?
Thanks again
marc
again i can't remember using non gen bits on one, you may struggle getting the right ones, if need be let me know and i can sort you out cheaper ;)
Cheers Fred, like I said..Legend!
going to try and get my car jacked up at lunch time to what the rack is.
