Which plugs
Car  Mk2 1.2 Campus
I got my cam belt, aux belt, inlet manifold, fuel rail cover, rocker cover and spark plugs changed last week. Since I got it done it's been spot on, until yesterday. I suspect the plugs are at fault. I used Bosch Super 4 from halfords. I've changed the coil pack which has had no effect.
Can anyone suggest which plugs to use?
Clio 172 ph1 ??
NGK PRF6E . If its been running fine for the past week i would imagine the plugs are ok . They are pregapped for each individual car , 0.85-0.95 .
Think I may have sorted it. I took the plugs off earlier and they look fine. T he battery is flat as the alternator is almost dead. Got the battery on charge to check if it's OK.
