White wheels.. going yellow-ish
  Static Low
Washed the car earlier and im really starting to notice the wheels are turning yellow-ish in some parts. Looking proper white again now after a good wash down and some AG alloy wheel seal.
Any info ?? Kinda worried about it, incase it continues to re-appear ! I wash the wheels at least every 2/3 days. Waxed them up a couple of times aswell since i got them powdered in october.
Thanks guys
  Static Low
Im going to hammer them with some AG SRP tomorrow. see how that goes. think thats okt o use on wheels, sure a read that christopher used it on his the otherday
Will probably just be brake dust, in the same way it turns silver wheels yellow if left for long enough. Just get them white and get a good few coats of wax onto them I'd say.
Coby.
  XC60-R.......V40-R
I'd recommend Bilberry Wheel Cleaner then a few Coats of SRP and a Couple of PB Wheel Sealant and see how you get on with that BUT White Wheels will always be a fooker to keep white
As above, but after using SRP i would put two coats of AG Extra Gloss Protection on then the PB Wheel Sealent.
Also might be worth Pming Christopher, as i know he has had a similar thing happen in the past. IIRC he sorted it out though.
Coby.
  XC60-R.......V40-R
Ah wasn't sure if you used EGP between SRP and PB's but I will stick a few layers on when I properly come around to cleaning my Wheels......I bought the Bilberry and PB's on your recommendations Justin :)
Need to sort my self out and clean it, but i think the above is a very good combo.
I think Rich uses a slightly different combo though, but different people prefer different combo's.
I will be doing my wheels when they come back from fred. Inside the wheels too.
