not sure but I think the pivot is to allow for neck support should you be hit from behind. They should be adjusted to suit before starting your journey
i only found out they did that last week..hav tilted mine slightly makes it bit more comfy but dont use it that much tbh except when i sit back for for a nap when stuck in traffic!
in short its fairly pointless y they r like that probly!
hi pepsi,the reason why they are hinged is that they are designed to absorb any impact progresivley ,rather than just having your head slam into the pad. it also gives a wider range of adjustment.
