Will a psh1 head fit on a psh2 BE?
Car  C63 AMG, F430 & 172
Without any breathing issues (crank case breathers etc)
Or are the bottom ends the a same? Bore stroke etc
I used a ph1 172 head on the (182?) bottom end I got from you
the cam covers are different for different oil separators...
heads are interchangeable though...
yes, just swap the cam cover and corresponding oil separator plate to match your existing config!
oh yeh, forgot about that :quiet: - didn't run it as the oil separator was mis-matched
you can still swap bottom ends over though i.e. install a ph2 BE in a ph1 or install a ph1 BE in a ph2
