Will i need Camber bolts?
Ok, from a bit of research on other forums looks like They are camber adjustable, so does this mean i need to buy the bolts? or should they be supplied with them?
Does anybody know howmuch ill be looking to pay for camber adjustment/alignment and tracking?
Prices range from £45 to £100+ for set up depends where you go and how good they are.If they are adjustable then you do not need caber bolts.
if you stay with the negative camber at decent values (-1 degree should be ok) I don't think you'll have to worry about tyre wear too much. just my opinion
