Will these discs fit my ph2 172? *Pics*
Car  White Evo V
My mate has a set of grooved and dimpled discs, They were originally on a clio 1.8 16v mk1 I believe but they look the same as the 172 discs. Can someone confirm they fit as if they do I will be buying them. (Sorry bout the quality, crappy iphone camera)
Also they dont have the abs ring on them but am i right in thinking you can take the abs ring off the old discs and put it on the new ones??
They look similar to what i have just fitted, whether the abs ring will fit is another matter.
They are ebc aparently so should be quite decent! and he only wants £40 with the bearings. They are brand new aswell, were put on the car for the mot but it failed on all sorts so hes breaking the car, they were only used to the test station and back - 6miles! just neeeeeed to know if they will fit???
i honestly can't remember, i "think" there's a difference, but i'm not sure, can you not borrow one to compare?
aslong as they are 280mm diameter on the fronts they should fit dude and you can take abs ring off and swap um over just becareful when doing that tho
Matty
