will these fit?
The centre bore should be ok with them being OZ's they'll just need the right spigot rings, it's the offset I'd watch for, it's probably quite high which might hit the strut. Anything between 42 and 36 should be ok
ok guys the wheels didnt sell so i need to know if they will fit, the info he has gave is PCD 100x4 and he says the the offset is ET37.
what questions shall i ask him so i can find if they fit?
Clio fitment is pcd 100x4 and bore of 60.1mm.
As said et between 36 and 42 is okay.
All of which is above. Therefore they should fit aslong as the bore is right.
final question, i need one replacment wheel for my set of super turismos, now if i get one with a different offset from the rest, what is the outcome?
ok i have had a email from the guy, he says the bore is 58mm with a ring which you can remove and will add 10mm onto the diameter. he says the ofset is 42 now! lol but that should be fine, how do i stand with the bore?
