Will these wheels fit?
I have a Clio 1.2 Vreg RT and it currently has 165/65/14 steelies on.
Will 185/55/15 vauxhall alloys fit?? they have 4 bolts/spokes
:S im clueless
Think Vauxhall alloys have PCD of 108 where as Renault are 100.
So if thats the case I'd say no :(
vauxhalls carry the same 4x100 PCD, but generally run a higher offset.
if its off a corsa c then they normally run et40-45 so you'll need either a 5mm or 10mm spacer to make them fit right.
check what the offset is, and then post up what it is to make sure
