Williams and valver front discs the same?
Put a williams disc on the valver passenger side and had all manner of weird problems since, just wondered if they were compatabile!
Only reason I changed was because drivers side was cracked, the disc I put on had about the same wear as the other side so didn't think it would matter too much!
But now drivers side is making weird squeeking noises, a lot of the time when im not touching the break, and also the handbrake warning light goes on and off when im driving!
i might be wrong but the handbrake light is only activated by a switch inside the handbrake assembly
Ok had a look at the brake fluid level but the bottle is pretty dirty, what level is it meant to be at? it was probs about 5/6cm down the plastic tube bit?
How come? Both discs are worn the same amount...
Anyone know about the brake fluid level, light is still flashin?
Yeah I know I should replace both but its just a money issue at the moment!
How dangerous realistically is it to be running discs which aren't worn exactly the same, whats the effects etc.
So I fill the brake fluid level to the top of that tube bit? lol
