Williams antiroll bar question
On the end of my anti roll bar in the bush. The bush fits OVER the antiroll bar and then a u shaped clip attaches it to the antiroll bar.Now polyspot sent me polyurethane bushes that seem to bear no resemblance to the original bush. The ones they sent attach via a bolt which fits inside the bushes and a bolt attaches to each end of the bush. The garage fitting them didnt see how they could fit as the bush is too small and slim. Are there two different types? I checked the code with Rally Desgn and they say it is definately the right code for a clio Williams. Is it that like other parts it can have a male or female component?
Anyone help please?
  172 cup,s2 rs turbo
the bushes they sent you are the commen type for the old clio(a bolt with a bush on it,a centre bush,a small bush and a nut).yours must be the one peice ones that slide over the end of the roll bar and attached to the wishbone by a u shaped clamp.best get back on that phone.
  ITB Hybrid+Cup+Scenic II
They have sent you bushes for the Valver...
The anti roll bar on the Willy is 2mm thicker than the Valver, and are fitted differently... :(
Michael
