Right now ive almost finished the suspension on 200 im starting to get obsessive about the coolant system. All temps below are at 70-80 cruising speed in this temperature (5 oC)
0002 water temp is normally at 1/4. 0002 oil temp is normally at just below 100
200 water temp is normally between 1/4 and 3/4 but fluctates up and down alot going between 1/4 and 3/4. 200 oil temp is normally just above 100
If just put some coolant system treatment in the expansion tank of 200 and run it and now water temp is the same but oil is just below 100. The coolant on 200 has been flushed in the last 2000 miles. My blowers are pretty hot in the middle and foot wells, but the side ones are pants. When i put the blowers on full the water temp drops a fair amount.
Im planning on getting the system flushed and anything else i need to get the temp down. Any suggestions and what does your Williams / valver tepms run at? I think the oil temp is fine but am concerned about the water temp as i think in this weather 1/4 on the dial is about normal, from seeing younger willys
