Wiring Battery to Amp.
Car  CLIO172, BMW3, 3061.
My wiring is currently set up ok however the power wire goes passed the hinge on my bonnet, Anyone know a better place for the wire to come thru?
thanks
^^^ if you cant get it through there, drill a new whole and stick a gromit in and then run the cable through there and then into the battery
on my clio i couldnt find the same place your looking for so used the wheel arch into the side of the door and round into the car, still works fine with no problems
ive got a bit old hole in my firewall with my 0awg power wire going thru it,
halfrauds FTL!
Use the hole for bonnet release catch. Just pull the rubber gromit towards the driver seat and it will pop out.
