wiring slimline fan
Car  Clio 182 cup
i wired my slimline fan at the week end i think i've done it correctly,
there are two plugs that go into the standard fan unit, one with 2 wires which plugs into the back of the fan and one with 3 wires which plugs higher up the fan unit.
i assume i have to cut the plug with two wires and connect to the smaller fan with spade connectors ?
but what do i do with the plug which has 3 wires ? surely it must do something ?
any and all help would be good as i'm worried my fan wont come on when in traffic
the other plug is for the resistor pack that a cup doesn't have (for 2 speed fan). Don't worry about it
cheers dan so what i have done "should" be correct i connected the black to black and the other two were red and blue so assumed they would go together and keep the the two blacks together ?
just try the connections. Polarity will effect if the fan sucks of blows, so test it. If it's wrong, switch the wires
hang on....leave the 3 pin plug alone, just leave it not attached. The 2 pin plug is all you need to worry about
ok will have to wait for it to come on and see if its sucking or blowing. bit of noob question but i assume it has to suck ?
