Woah, tyre pressures.
I did a bit a hard braking from high speeds earlier, and the car was snaking all over the place! Seemed to be pretty hard to control.
Anyway, it concerned me a little, so I went up the garage to check the tyre pressures, and they ranged from 37-42 PSI!!! :mad: Only had the tyres put on last week, so it was the tyre place. Not too happy to be honest.
thats pretty dangerous! :( what do you normally run? i use 30 front 28 rear on my 1.2... what does everybody else use?
I had this also, had 2 new PE2's put on at local tyre fitter and when I checked my pressures they were up at 40PSI!!
mate i never trust any garage or tyre fitter anymore.
My pressures were out and my bolts were loose.. front 2 were so lose i could remove them with my hands..
crazy.
Thats just the slightest bit dangerous! :dead:
yeah couldnt believe it. Kept hearing this banging noise stoped to see if it was a puncture. Came on here and the lads here said check the bolts.. couldnt believe my eyes mate.
BenR [Angelworks] was doing some work to my car the other week and checked my bearings and tyre pressures and said mine were inflated to 40psi !
Thats after it had been to a Renault garage for a main service.
Tut Tut.
BenR or Yozzasport for me next time, no more Renault rip off.
