wobbling/twitching at all speeds
  Clio 1.6 16v 2003
i just lowered my car again is was -40mm now its -60mm , i now have a case of the wobbles even at low speeds (30mph) its quite twitchy as well now.
is it just a case of alignment or do i need camber adjustments?
never had any wobble on the other springs untill reaching about a ton on the m1.
anyone with similar problems that have been solved please tell me how
thanks guys.:)
  Clio 1.6 16v 2003
it feelslike through the steering wheel that im driving on a pebbed/stoned driveway.
i take it u dont have a clue either liam? how can it be fine -40mm but terrible @-60mm , confused.:confused: come on techys??
Not kerbed (buckled) a wheel?
Mines lowered more than that and i got a bit of steering pull where the tracking was out but that was it.
-Rob
  Clio 1.6 16v 2003
no i just changed the springs this morning, the wheels were balanced last month.
the steering wheel just shakes from side to side.:confused:
Well i got a vibration in my wheel, a sort of rumbly feel, result, new driveshaft, i dont remember it shaking from side to side. Get it booked in i guess.
-Rob
  Clio 1.6 16v 2003
yep tis a rumbly feel like the wheel is fighting to stay straight.
wheres best to go an ats round the corner or somewhere that deals with mods to cars?
  Clio II and Grand Modus
If your on std. dampers that could be the reason too, they handle crap at - 60mm!!!But if your camber,tracking is incorrect this would be the first to get done........
  Clio 1.6 16v 2003
right its sorted, turned out to be a 1.5 mm piece of aluminium off the spacers in the wheel.
when the wheel had been put back on after the springs had been done it had been chipped off and got caught between the wheel and the hub.
therefore the wheel wasnt sitting on the hub correctly
thank god no wobble even @ a ton.
