Wonky KTR Ultrasport
Car  Clio 182
Hi all,
finally got all my brackets from k tec and had a local garage fit my exhaust....... But it's wonky it's been back twice and they can't centre it properly it has all new hangars from Renault. So other than the obvious lesson learnt (if you want something done properly do it yourself) has anyone got any advice they can offer an exhaust fitting rookie? Case of playing around with the rear hangars? Or is it a cable tie job?
Probably a very amateur question but I can't be dealing with an exhaust that looks like it's been fitted by a 12 year old
Not the best picture as I'm at work but one pipe sticks out further and the left one seems to be almost touching the plastic trim :/
It's not the best picture but it's noticeably over on one side and one tail pipe sits about and inch further out than the other
It dont look to bad but I no the feeling when it dont sit right it drives you mad. It can be sorted
You might need to adjust the rear bumper.
Underneath there are some clips (around where the tail pipes are) that you can undo which will then allow you to either move it in or out a little bit on which ever side needs it. That will make it look less like one pipe comes out more than the other. I had to do this on my car
Hope that kind of makes sense but it most likely doesn't haha
Ah Right I will have a look after work! That could definitely be why one appears to be sticking further out. Are they easy to adjust?
Off to check this out right now, thanks!
