Writing a batch file.
Calling all geeks, I need a small bit of help.
I'm trying to write a batch file that will run "test.exe" and key stroke "inputtext" and then press enter also write the output from "test.exe" to a text file.
"test.exe" doesn't work with with parameters
So its not like I can just use "c:\Test.exe -inputtext > outputfile.txt"
If the input parameters are not allowed then I don't think theres anything you can do with DOS.
I used a click-macro free trial program for something similar once.
