WTF, Disc snapped, caliper in alloy
  don't
Ok
my mate now had my 1.8 8v rsi
1995
he was driving along, then the rear drivers wheel just locked up, he heard a loud bang just as it happened
I got there and his rear disc was snapped in two, then brake pads were all over the place, and the caliper was kind of jammed in his alloy spoke
A tow truck came out and said he thought the discs were probably weak and the caliper may have seized and caused it all
So I guess he needs new discs/pads, and a new caliper
wheres the best place to get a rear caliper drivers side, one site said it was £100, thats a fair bit of £££ 2nd hand would be fine
anyone ever seen this happen, the guy took the wheel off and tried to push the caliper etc back towards the car so that the wheel could turn but it wouldn't go back in enough
PM matbrown - he might have one depending what sort of caliper is on the RSi;s. If it's the same as a 16v/Williams, then he'll have one.. I get the feeling it is as the RSi is the only one with rear discs apart from the 16v/Williams.
  Audi TT 225
He should get the alloy checked too, it would have taken a heavy impact if the caliper flew off and got wedged between the spokes while the car was in motion.
If a weak point had developed around one of the bolt holes on the disk then it could have started to crack and eventually would break in two if it was under enough stress...
Really bad luck tho :(
  don't
alloy didn't look too bad tbh, caught the back of a spoke and took a slight chunk out of it but nothing major
will have to check its not bent at all though
So far been quoted £40 for a used rear caliper, including delivery
  Audi TT 225
I would get it ballenced just to be sure, that should tell you if the wheels ok. If anythings bent or buckled then its gonna be wonkey
  don't
hmmm, I think the 16v and the 8v use the same rear calipers
if so I've found one, anyone know if they are deffinately the same
  don't
apparently it needs a new rear sub axel aswell
what the hells that, cost wise??
any idea's, I'm guessing its just the main bit around there that holds it all together
MRBILLYUK
  FF Jeden Osiem Dwa
