Xbox 360 Problem
Car  RenaultSport 172
I've just gone to switch on my xbox and it's freezing on the dashboard screen?
I've has a quick look on the internet and it says to remove the HD and then try it. It's not freezing then, but it says I need to clear the cache? But I can't do this unless the HD is in the Xbox and if it is it freezes?
Will a new HD solve this problem?
Does it crash just after it connects to live? Try disconnecting whatever method you use to connect to xbox live and turn it on.
If it works offline, do you have anything in your download queue? If you do, remove it by going on your account on xbox.com and then try starting and connecting to live.
If it still doesn't work offline then it could be the cache, would be better off trying to clear it on someone elses xbox than buying a new one, official hdd are a rip
Cheers mate sorted now.
I put the new Halo: Reach trailer on to download, thats what must of caused it!
Also My ODST disc is now damaged! all other discs work fine though.
Cheers again, Sam. :)
