Xenon ignitor to bulb connector what does it look like?
Car  172
Today after a quick wash and drive i found my drivers side xenon wasnt working. After I had a quick check on here i found that it could be the fuse due to water getting into the ballast or an ignitor my problem is whilst the fuse was easy to check i wasnt so sure about the ignitor. In this thread http://www.cliosport.net/forum/showthread.php?624412-Xenon-bulb-blown&highlight=xenon+bulb+blown on post number 6 it says to check this I pull out a green connector the only similar thing i could find was a connector with 3 or 4 green wires. Is this the right connector to check?
99% certain it will be water in the ballast, ive heard of some people stripping the light and hairdryer the ballast and it works again, i had same problem and had to get a replacement though - £50 on ebay, unlikely to be a connector, unless you were cleaning under bonnet. 1% says i could be wrong tho :p
