xenon..MORE F***ING PROBLEMS
Car  172 ff for sale
went to my car last night, and the headlight light stays on in the car even when the lights arnt on. and when i do turn them on the xenons dont work?
this happened before 1 side comes on 1 side goes off :dapprove: but now none are on
is there a lose wire some where?
where should i start?
the fogs and other lights work fine
THAT SOLVED THE PROBLEM, BUT NOW 1 SIDE ISNT WORKING GOING 2 GO GET A BULB, IF ITS NOT THAT MIGHT BE THE THING WHAT HOLDS THE BULB BALLAST? HOW MUCH ARE THEY?
NOT SURE MATE YOUR BEST BET WOULD BE TO CHECK WITH RENAULT BUT THEY WILL PROBABLY QUOTE SOMETHING STUPID So HAVE A LOOK ON EBAY FOR ONE BEING BROKEN.
O RIGHT WELL CHECKED BOTH BULBS AND THERE BOTH WORKIN SO MUST BE THE BALLAST, ILL CALL UP RENAULT SEE IF THEY HAVE ONE IN, AND IF THE FAULT IS STILL PRESENT WITH THE NEW ONE SEE IF THEY WILL TAKE IT BACK
Internal ECU that controls all the electrics. Situated on the n/s up behind the dash. Very common fault ( do a word search on UCH )
