Xenon Washer Jet - only one working
Car  "Navy" N17 TWO
Done the search but can only find problems with them leaking :S
My Drivers-side Xenon Washer isn't working, everything else is ok.
If there's dirt/grit blocking it, how do you take it off to clean it?
Any other ideas of what could be wrong?
Trev
Sometimes they just stop working! Get a new one 12 quid from renault bumper off and replace it. Takes about 3 hrs max
All the pipe/lines are in the passenger wheel arch if you strip the wheel arch liner out, then if you can't solve it, continue and remove the bumper.
I changed both of mine about a month ago took me an hour start - finish.
Can't find the dam guide for removing the bumper now
Why remove them Craig? :S
because mine have been changed god knows how many times. and ones leaking now. ive got a spare washer for it though so if its easy to fix ill leave them
