Anyone who can help get my clio 172 running / diagonose . Will pay
Car  clio 172
After re-installing engine after having cambelt and dephaser I cannot get my clio to start .
its turns over , it's getting fuel to the rail but injectors do not fire .
Checked for spark , getting spark .
ive noticed throttle body is not opening when press pedal , swapped pedal and throttle body but the same .
also checked it's not immobiliser .
electrical fault light on dash .
Need help despeatelty :-(
Had the car almost 4 years and never driven the car .
Ive had abit of bad luck over the years , serious car accident and currently have knee ligament damage .
ive tried my best to get it going but seriously struggling and getting down about the situation I'm in .
I coukd get it towed if it helps .
If theres a warning light on best thing to do would be get it plugged into a diagnostic machine and it should give you some idea of the fault.
Are all the connections on the engine loom connected?
Check the 3 little relays in the engine fuse box for corroded terminals.
Give the loom a tug and a pull in various places then try it.
May be worth checking all the fuses in the engine and dash fuse boxes.
Where abouts are you?
Wrexham buddy .
ive had alook at fuses and cleaned up contacts on ralays .
yeah has a fault light on dash .
couid be a simple fix for somebody who knows what there doing
Yeah I have connected them but one is not looking so Great .
could this be the issue ? How do I repair this earth ? Could I solder a new wire and bolt to the earth point ?
I might be about this weekend might be going to Chester for some parts and DT to for brake pads PM your name address and phone number and if I go to Chester I'll look you up and see if I can help you out.
No I haven't Modified the loom .
Removed Engine & gearbox to have cambelt & dephaser done , which Birchdown done. fitted new pumps and PAS etc 182 Manifold.
I think before engine was removed on the day when I tried to start it , it wouldn't so what ever the issue I think it had happened while sitting on the drive !
could be a bad sensor or wire I guess as the dash indicates somethink
You think it didnt start?
Seems a weird thing to not be sure about. Most people are pretty sure if their car didnt start, lol.
If its sparking then it doesnt sound like a sensor issue TBH as the ecu has to be pretty happy with its inputs before it fires the plugs.
Chip it was along time ago when I started this and I had a car accident which left me in an air ambulance so i can't be certain .
im really struggling and have no clue and pretty close to giving up and selling up .
I have no experience with these and want to get on track and enjoy it.
Ive had the car 4 years and drove it once
