Rear beam lower shock thread gone - help!
  Clio 172 (CUP)
Hi,
Been slowly reconditioning the rear end of my 172 cup, previously shot blasted and painted rear beam and mounts, powerflex bushes, suspension refresh cleaned up stub axles and painted callipers which I'm about to rebuild, new brakes to make up ...the whole shabang.
Just fitting the reconditioned whiteline arb today, went well until refitting lower shock bolts (new OEM ones), and the worst happened. Went in absolutely fine, just torquing it up and felt like the bolt was snapping/twisting - it wasn't, it was the axle thread being chewed up. Evident by the shredded metal falling out when removing it. Rechecked it, yep its f**ked.
No idea why it happened, might be just bad luck, totally gutted to say the least :(
Does any have any advice on how to go about rectifying this without a new beam? Was thinking e.g.
- Oversized bolt and add nylon nut on the inside
- cut out and re-weld the bolt carrier/thread (don't know if these parts can be bought separately from renault, otherwise would have to go second hand)
Any help would be much appreciated. I've got till near end of August to have the whole car finished for a booked track day, though seems an up-hill struggle lately and starting to fall out of love with it :(
  Clio 172 (CUP)
He does a good job as well, saved one of my customers over £700 by sorting out a cross threaded issue.
@Mike@Rentech Thanks allot for the recommendation, I now see light at the end of the tunnel again ;)
'Dave' @ Thread Wizard is a top bloke, we decided it was too far away to make it cost effective for me to have him come so far, so he preceded to talk me through sourcing the kit and and how to go about it myself, even to ring back when I come to do it for more advice - total gentlemen!!
  Clio 172 (CUP)
Not wanting.to state the obvious but just stick a nut on it.
That's what I thought first, and probably what I'm going to end up doing anyway. Although the recoil product is more than adequate, for this situation a longer bolt and a nyloc nut + washer is cheaper. Plus as I'm fitting an ARB, I need a longer bolt.
  dan's cast offs.
the standard bolt is fine with the arb, think it might even be long enough to get a nut on as well?
  Clio 172 (CUP)
With only the ARB on yes it is definitely long enough, but IMHO there isn't enough thread to put a nut on securely and satisfy my paranoia ;)
