Can the yaw sensor be moved/removed?
I think that's what it's called? The unit which normally sits under the handbrake cover?? I'm sure that what I saw you call it mate @Dan@SJM
Can it be removed or moved else where, say up into the dash without any problems? Or will it cause a problem with dash lights?
Also,
Does anyone know of anyone around Croydon who has Clip and can sort out some other dash lights for me? Airbag, serv etc. I know they're not a big deal but I'd like to keep the dash lights as minimal as possible. I'll always have some lit though because of the Jenveys.
Not really mate. It's calibrated so if it's moved it'll cause all sorts of false readings. I can do the airbag lights if required.
What problems might these false readings cause? I had to move it out the way whilst I had some new seat mounts welded in. So it's still loose in the passenger foot well at the minute.
It's a track car which has been gutted but this and the air bag ecu is one of the last few things I need to sort out.
I would happily give you my money lol, your're just a bit far to be worth it, and I don't suppose you're around Croydon very often lol.
I'm down that way weekend after next.. Well, Redhill anyway!
It'll bring up lights, and if the esp is on it'll interfere with the car
All my lights were on anyway so it's a bit of a mess lol. Don't know what is causing what to light up now.
So basically I would like as many of them turned off as possible. I know there will be the engine management light and electrical light on still though because of the ITBs.
I'll message you now mate.
Still need all this sorted.
All my air bag wires, sensors, yaw sensor and crap are tied up and in the passenger foot well at the moment. Would be good to get rid of it all for good and sort out CLIP so any lights go off.
It's a proper mess at the moment inside the car now.
Does anyone know anyone with CLIP in the Surrey area. Closer to Croydon the better.
