Any truth in this as I have a set of brembos in the shed. So will hang on to them if they fit.
J JoeMarano 172 Nov 2, 2014 #1 Any truth in this as I have a set of brembos in the shed. So will hang on to them if they fit.
172lover Williams Nov 2, 2014 #2 When you say brakes.....you mean the discs?? I only ever heard the rear caliper's are the same(not sure about carriers...) What size are the discs? 172's are 238mm
J JoeMarano 172 Nov 2, 2014 #3 Just checked on the box. Apparantly they fit a phase 2 clio but only up to the year 2003 and mines a 2004.
welshname ClioSport Club Member Golf R Wagon Nov 5, 2014 #8 marinemackay2003 said: 306 gti 6 pads also fit the rear calipers iirc Click to expand... I thought that was the fronts? Pretty sure it is. @Budgie will be able to answer that one.
Budgie 330i. E30 Touring. Nov 6, 2014 #9 Yep, GTi-6 / Rallye front pads are the same as a Clio 1*2 front. Rear calipers and pads from a 1*2 are the same as a 106 GTi, Saxo VTS. Can't remember about a 306 or not - will check mine tonight and have a look.
