Worn gearstick ball joint housing. Where to get replacement?
Battery Nonce
Hey. I've noticed that when in gear my gear stick wobbles crazy lots all around.
I searched and found that to check, you remove your gearstick gaitor, if your ball joint housing is okay the black rubber insert should stay put and only the white ball bit moves however on mine the black rubber insert is all over the shop!
Where can I get a replacement please?
Cheers!
bashracing
Yanoo stiff shift replaces it dan,
Have one fitted to a scenic lever in mine,
Great improvement,
Alternatively ash is doing a modification in the group by section
  Nissan 350z
Mine was £56 as I didnt need the stiffer ball joint insert. It depends which design gearstick you have but he will help you clarify.
