Jack's Clio 1.2
..Jack..
West Midlands
Right here's my 1.2 Clio it's one of my daily drivers not the biggest fan of the colour but it's alright replaced a sunroof seal, carbon canister and coil pack! I'm looking at doing a couple of things such as refurb the wheels colour code boot button, get towbar covers and get a better sound system and a new damper as current one is weeping! So here it is!
Suggestions of what else to do please! Ohh and I also plan to gloss black interior wrap in places!
It's very easy to pour ridiculous amounts of money into a non-sport clio. After doing it twice my recommendation would be not to start modding! However, no one would've been able to tell me otherwise so if you're looking for inspiration, have a look here: http://www.cliosport.net/forum/show...-In-Here/page124&highlight=non+sports+in+here
and here: http://www.cliosport.net/forum/show...-Skint-People&highlight=mods+for+skint+people
Depends how much you want to throw into it really and how you want it to look. However, I think as you mentioned colour coding the boot button, that'd be a good start. You could probably also colour code the side strips yourself for fairly cheap.
I've done more things to my car than I could even list, it makes me shudder to think that I've genuinely spent over £1000 on cosmetic mods on my current car, and I'm still not finished with it yet!
Best of luck, enjoy your car!
Cheers mate literally it's just going to be a really small amount of things to do on it, as I say it's a daily driver and a good workhorse
Okay cheers! Now they both push into the door shut and lift off right?
Yeah that's right. Takes a bit of force to do it the first time, if you use some sort of tool to push them, cover it with a cloth so it doesn't scratch the paint.
Right I have thought of a few more things! Rear 12v socket, change sound system remove fried egg effect and some led bulbs
Cleaned it yesterday and sprayed the grille, removed clio badge ready for new one and experimented with the 16v part of side strip!
A lot has happened since, good and bad
Latest thing is the sunroof started to leak again this evening! Also a Wheel cracked so I got a replacement from a scrappy for £30 and now 2 new tyres are on the front (Ventus Prime 2) I've also received and fitted all of my ebay bits and sprayed the wheel nut cover bolt grey to match the wheels!
And the second hand wheel after a clean :)
Sprayed bolts :)
And the car got a clean! Excuse the steel spare in the photo!
Also started on my new project which is a Fabia 1.8T conversion!
So it's had a second hand engine out in since and now I've took it off the road and bought a van until I can get all of my list of jobs done on it as it needs the work and I want to get it all sorted before using it again! Lists.... Things to do:
Cam Belt and Water Pump
Repair Exhaust backbox
Replace sunroof
Clean interior
Make my own phone dock
Bluetooth stereo
Replace melting steering wheel
Refurbish Alloys in my garage
New working speakers
Fully repair dented bonnet
Permanently fix dodgy passenger seat wiring
Get Cigarette lighter working
Service
Rear Shock Absorbers
And that's all for now :)
Ohh and also de tango lights
RS Grille too
Check brakes
Rear dashcam
Stubby aerial
Spray the faded interior trim
Colour code side strips, door handles and the spoiler on roof and boot centre button!
I have progress sadly it really isn't good!
Car has been reversed into damaging the front end so might slowly start to make it a 1*2 rep!
That didn't happen, I just repaired the bumper, not much has been done except putting some Pioneer speakers I have from one of my previous vans into the front and rear. Painted the rear drums silver as it was annoying me and fitted de tangoed indicator bulbs as well as sorting the headlamps out properly.
Last one is how they looked before I sorted them!
These arrived today! Not bad to get 8 pads and 4 applicators of good quality for £18 :)
Update:
Fitted new side strips which looked gash and were removed instantly.
Sunroof leaking again, need to check which part this time.
Fitted some Blackvue front and rear cameras.
Did a garage clearance in it earlier, hooked up a braked trailer, about 900kg fully loaded, quite surprised at how well it went.
Someone cut your brake lines? Wtaf??
Yes there was an on going thread on Briskoda which is gone now but over the past 6 months we've had cars keyed and glass smashed, wheel bolts loosened and then nothing for a while until the car was left out of CCTV camera range and then it was cut.
Repaired sunroof, needs a pair of new rear shocks. As I was moving it EML light came on but I've left my scanner in the Jag :(
Right, my Bluetooth stereo plus remote adapter lead arrived last night so this morning I fitted it all up and am delighted with it, I've also had 2 Blackvue cameras fitted by myself. Head unit makes such a difference with my new speakers a few pictures excuse the mess.
