High pressure power steering leak - out of ideas :(
  Clio 182
So my second problem of the week with the classically french 182 - my power steering hose ( high pressure going to left axel ? ) has been worn away by the heat shield.... there is now a small pin sized hole that fluid is slowly dripping from ( loosing about 1ml every mile)
Ive tried using metal alraldite epoxy to seal around the hole , but she's still leaking
option A : scrape off the epoxy and then mig weld over the hole? ( is this a good idea since access is very limited?)
option B : how easily can that pipe be replaced? - it looks an absolute grade 1 pain
https://www.dropbox.com/s/nzvfe7owzjgenlx/IMG_3174.jpg?dl=0
https://www.dropbox.com/s/lw4fwzkai5r95xg/IMG_3175.jpg?dl=0
photos show the pipe - its the one covered in epoxy :(
anyone had a similar problem like this ?
Grandpa Joe
I've got a high pressure hose ready to post. Replacement is the only fix.
There's the connection at the PAS rack by the steering column joint and a couple of bolts securing the pipe along its length.
It's not a bad job, bit of patience and some rags and a tub to catch the oil is all you need really.
  Clio 182
on closer inspection its the reservoir to rack pipe (i think thats low pressure) that i need
same as the one in this picture - http://thumbs1.ebaystatic.com/d/l225/m/mci9M0uec4zce0-CQL8m6qQ.jpg
if you have that then please let me know! :)
thanks
