clio 172 revving flat out all of the time?
no just changed down a gear to go into an island (not quick) it like surged forward, coming out of the island it just took off and has been like it ever since havn't got round to sorting it
can see any air leaks at all, throttle body is shut, going to try and take the throttle body off and clean that and if that doesn't cure it, unplug the accelerator pedal and turn it on see if it idles normally
Sounds like an air leak somewhere I had the same. Although mines was due to removing the carbon canister from the breather and not blocking it off correctly.
Cover it good with duct tape and see if it helps. If so then you know it's that then obviously block it suitable after. That's what I done.
with the inlet off or on ? and ill will have do do it tomorrow as im at work now and out later on, the breather that goes to the intake pipe is fine, the one when you take the inlet off and the part that sticks up into the inlet, the pipe to the left of that (by the engine crane hook) hasn't got anything attatched but it has been like that since day1
PH2 with fly by wire throttle body?
Get the fault code(s) read and check wiring for corrosion before replacing any parts.
Does it still rev with your foot on the brake pedal?Any warning lights on?
no fault codes are coming up, any rough idea were they usually corrode ? and no it holds it back. no waring lights
Check your mat hasn't lifted up on to the throttle peddle, this happened to me once it took me a while to work it out ha.
Well i had a quick look tonight and within a couple of minutes, found this that i think the bolt has gone walkies that was blocking it off. Also the clip was loosr
So i plopped a new bolt in and tightened it up
Well guys thank you very much car is now sorted :) the one to the left on the breather on the rocker was open, blocked that up :) and the 1 by the throttle body, no idles and drives spot on few more things to do, got to sort a build thread out
