Will 14" wheels fit over the front discs?
Trackslag172
  03 Clio 172
As per title, I am looking to get the smallest wheels I can on mine to improve acceleration (at the cost of top end) in preparation for my next Brands Hatch Indy track day.
I have 15" Superleggeras, but would like to get some 14", but want to know if they fit first.
Cheers,
Tim
Trackslag172
  03 Clio 172
when my tyres need changing I will get 45's as Im also trying to lower the car more as well But i'm hitting clearance problems as my new suspension has increased the caster which means the wheel is hitting the arch further forward. I think I will just end up grinding out the bit of the arch that the wheel is hitting. I will work out the pros and cons later, Ive had some wine and if I decide now I will end up cutting out everything to save weight
Cheers,
Tim
Trackslag172
  03 Clio 172
Is it a ph2 then? That rubbing issue takes minutes to sort
Do tell, the only way I can think of is to grind out the arch some more!
Pic of where the wheels are rubbing on the arch
Trackslag172
  03 Clio 172
I cant seem to get the pic to rotate but you get the idea.
A hammer won't do it, ive tried. Need to cut it out!
Djw John
Scotland - South
Not so important on drag cars. Only braking once!
For track use 15s are ideal, there's a reason they used them in the Clio cup back in the day
