Played for the first 2 weeks, bought gta v again and fallout 4 has been in a drawer ever since
			What?If you have that quest/objective marked as active on your Pip-Boy then it should put a marker on your map and a marker above the NPCs head when you're near-by?
Laters.What?
You've got to think AND put effort in?
I mout
When you're in the workbench, you can "tag" items that are part of a mod, then when looting you'll have a magnifying glass next to junk items that contain those pieces. I had the same problem with oil until I started doing this.Do you get screws from fans? I need a load for some weapon upgrades and only have a couple from toy cars!
You do once you put a point into the Scrapper perk.Do you get screws from fans? I need a load for some weapon upgrades and only have a couple from toy cars!
Just keep plodding along. You'll know when it's time to make that decision. I held out until the last possible momentNeed some storyline related help..
So I've currently just been to the institute and the Prydwen so my story is about to split somewhere!
How far can I go still doing all missions for everyone so I can maximise XP.
It took me a concerted effort to actually do some main quest and even then I'd stop at every location on the way to loot them out.There's a storyline?
This is probably the best game I've ever played tbh. I'm not a massive gamer, I own this and Forza, but I've already sank 50 hours into it after getting it on the 17th. About Level 30 and still feel like I've barely started the story. Just like mooching about and picking up EVERYTHING.
There's a mission for the Institute called Mass Fusion that will make you hostile to the Brotherhood.
There's a mission for the Railroad called Underground Undercover that will make you hostile to the Brotherhood.
There's a mission for the Brotherhood called Tactical Thinking which will make the Railroad extinct.
There's a mission for the Brotherhood called The Nuclear Option which will make the Institute extinct.
Personally, I made saves so I could go back and follow all story lines. The best one is going with the the Brotherhood, it has the most quests and the most fun quests. For reference, when I finished the game the institute route I was at level 38. When I went the Brotherhood route I finished the game at level 45.
Yeah, it's worth doing the saves, just remember (write down) which saves are which and don't overwrite them.Thank you, that's what I needed to know with out checking through walk throughs as to which mission stopped stuff.
Me and a friend are at similar points and have said the same about creating a save point we know to go back to. Although we're definitely going to play through again once completed.
I doHaha jay do you have a job?? How the heck can you get to level 90? I'm only ranking up levels very slowly now
Sucks there's a build limit. I could build so much moreI've almost filled my settlement on the island. Ps4 problems!
http://www.se7ensins.com/forums/threads/bypass-settlement-size-limit-exploit.1406777/I've almost filled my settlement on the island. Ps4 problems!
Cool will give it a go cheers@Jay_A see above, you can build more!
Just did tactical thinking - didn't realise as soon as i took the quest railroad would be my enemy
The next quest had a better idea where it said 'warning - when you get on the vertibird the institute will hate you for ever are you sure etc'
Oh well
