Leeds_182 LOLvo barge
Yeah, joes. He's doing a restoration on it.
Shame but I guess it's better than you having to do a lot of work on it.
Jim, do you know if the low pressure ones of these are just a different turbo or is it a case of winding the boost up?
Or do they use a different engine/turbo set up all together?
No difference with the low and high pressure other than where the boost is set. You can wind the low pressure up to 12psi on the low pressure one no problems.
Once over today;
Ordered some vac pipe so should be able to turn up the boost this week.
After looking at some 940s on the net I decided to paint the front grill satin black.
This is how it looked at the start;
I'd spent £2 on the paint from the pound shop! Roughed up the surface with some sand paper and then hit it with a few coats of grey primer;
And then a few coats of satin black.
Refitted and then went out to take a few pictures;
