Clio 172
Do these have an immobiliser ring on the barrel.
No idea what that is!
Clean up where the earth strap from battery to body or replace the cable
If you have zero mechanical minded sense then I would leave it alone and if it happens again get someone to look at it or you'll be causing more harm than good mate
Check the small low tension 12v exciter wire connection to the alternator.
If not properly connected,engine will crank a couple of times without firing and then throw in the towel.
I don`t know why,but have witnessed this as a fix.
Admittedly it was on a 1.2 litre Clio.car will start and run without it connected.
Cheers pal.Thanks everyone for their advice!
Sorry mate just jokingDefinitely not you, king piss taker!
b*****d 😧
You should be charged with all your negative replies.Looks like you just jump started the thread againSorry mate just joking 😧
didn't watch them. think was your first post about shift light coming on...hold on...
Totally agree,should still run with a good battery even without an alternator on board.should still run though. single wire?
