205 Endurance Racer Prototype
I've not got a clue what's going on in a lot of them photos but never the less it looks sick.
He said 192bhp in an earlier post, as per standard formula renault 2.0. Not sure if this is still the case, but it certainly was as of about 2 pages ago XD.
Awesome work mate, well done!
Yep, still the case! Not going for silly power but useable performance and easy to drive.. should still be very quick though!
superb work, and it must be one of the most exciting things to know that once its done, you'll of built your own car, from scratch, truly deep doff of the cap to you sir!
hope you make the test.....in 3 days!!
:fearscream:
Best update this, then!
The car is getting very close to done now, but it won't make the 25th Feb test day. I could reel off a list of reasons but it's easier to say there was just way too much to do in such little time, no room for problems, and the reality is there's 3-4 weeks left until the thing will be ready to tear down for paint & powder coat. The list is growing ever shorter though, and is now down to: coolant plumbing, wiring, fire extinguisher, fluid lines, windows, a load of small finishing touches.. ok still a fairly long list then.
This week I've finished up the body mounting - the only thing left now is some hinges for the rear clamshell. We want to retain the original headlamps and indicators, so I had to make up a frame to hold everything in place. The lamps that came on the shell were knackered so my own GTI donated some bits for the time being!
Looking pretty good now!
Then I fitted the (tiny) fire extinguisher and battery..
And finally.. this is the gap I have to get cooling pipes through! 😢
Not an easy job, that one!
Getting exciting now!! Deadlines are there to be missed, so do it once, do it right and screw the timings ;-)
Looks so good. Hats off my friend!
Can you not get coolant pipes down the side of the passenger seat?
I did want to send them down the driver's side originally, as there's a bit more space that side with the seats being shifted over, but there were a few problems with it.. the biggest being that avoiding the pedals / driver's feet was almost impossible, but even if I could there was a problem with the lap belt which would have had to rest on the cover - not ideal. The passenger side is out because of the same belt problem and they'd end up on the wrong side of the engine, so the centre is the only space left!
Update time!
The job I've been dreading actually turned out to be pretty enjoyable, which is nice! I got off to a bit of a dodgy start as I had 10m of aluminium tube but no bends and couldn't find anyone to make me any, but was rescued by a little-known place who had a bin full of them in the correct size - apparently no good for F1 but just fine for me!
Started off with the most restricted bit around the shift lever. I'm going to have to trim a tiny bit of the bracket away to avoid rattles but it's actually not as bad as I feared!
I had to come up with a way of securing everything that still enabled me to slip insulation over the pipes, so made some little P-clip brackets
..Which then attached to some L-shaped brackets that bolt to the floor. There's room above the pipes to secure the brake, clutch, and fuel lines too.
This is how close everything is around the shifter..!
It all looks pretty nice. :up:
Then I moved on to the front end, routing from the shifter to the radiator. This was a bit fiddly as the hot pipe is below the cold, but on the rad the inlet is at the top, so the pipes needed to switch around somehow along the way.
I opted to do the cold side first..
Hot took a bit of fiddling to get right, but the pipes are parallel which is what I like to see :cool:
Then to finish off the middle bit I made a little pass-through for the engine bay firewall
And finally I routed from the firewall to the water pump and thermostat outlet
Frustratingly I need ONE MORE bend, as the thermostat housing is 28mm and points in the wrong direction, so I can't 100% finish it this week! I'm pretty happy with how it all came out though, and the nice thing is there's no impossible geometry so they can be CNC bent later if required.
this is coming together now! I'm anxious to see more updates all the time! hopefully ill get to see it at a show or something for real. Love this read, keep up the good work.
I'll do a proper update over the weekend! :tonguewink:
Just put it on the corner weights and it's standing at 767kg dry, so should come in wet at around 840kg.
ETA: 56% Rear weight distribution, likely to be 55% wet.
I get excited when I see the email notification on my phone lol
Looks incredible bud, hats off to you.
Can we be expecting renderings/photoshops of the finished article colour scheme? Or you leaving it bare until you've had a shake down session with it?
Oh my word....group B days are here again :hearteyes::hearteyes::hearteyes::hearteyes::hearteyes::hearteyes:
Have you thought about doing a Youtube show? I would bet my life it would be a massive success and make a fair bit of extra money for you.
You are producing high quality builds and doing it at a very quick pace too. There is a youtube show which I love to watch but it just doesnt make enough videos - project binky . You would be way ahead at the pace you work.
Some of the talent on this site is incredible. If I had some cash I'd open a garage and employ all you f*****s to make me some good money
Can i get a fivers worth of shares in that please? [emoji106]
This is an epic build and will forever be one of the best. Shame it's not clio shaped, then it would be perfect [emoji38]
