Parts Required For Brake Caliper Refurb.
Nyall
  Titanium Ph1 172
Hey guys,
I'm planning on refurbishing my front brake calipers myself, I'm just wondering what parts are required?
Planning on getting a Bigg Red rebuild kit http://m.ebay.co.uk/itm/Renault-Cli...r-Seal-Piston-Repair-Kit-BRKP87-/271651814388 which consists of the rubber seals and pistons.
Is there anything else required or recommended that needs replaced/renewed?
I've read about caliper slider pins, are these available from Renault?
Any advice would be appreciated!
  Clio Trophy
im getting mine done soon, and would interested in what other parts to freshen up at the same time
Nyall
  Titanium Ph1 172
Rubicon_
  Defender 110
Are these the correct pins? As there are two sizes listed... 72mm and 62mm?
I measured mine to be 72mm, not sure if most are this or not. Probably best checking once you've stripped down.
Nyall
  Titanium Ph1 172
If yours measured 72mm on your 182 then I'd imagine they'd all be 72mm on the 1*2's.
Nyall
  Titanium Ph1 172
I'll go and have a look at my discs before I order the sliders.
Nyall
  Titanium Ph1 172
Vented discs on the front and single plated discs on the rear, so I'll get ordering some 72mm sliders.
GrahamS
  335d, GT4
Do you really need sliders? I've never had to replace sliders on any of my 1*2 calipers. It's quite the opposite of a must! Just clean them up, chuck some lube on and put a new seal kit in. Jobs a goodun. When you take the piston out if it's ratty then replace it but some light scoring doesn't do any harm.
Be very careful of the bleed nipple as they snap easily. Clean up the area around it, drench it in penetrating fluid and then tap it with a hammer. Hopefully that will break the corrosion up to let you get it out. I replaced my bleed nipples with stainless ones. I think it was these but I might have recalled totally the wrong size. http://www.ebay.co.uk/itm/4-x-M8-x-...361?pt=LH_DefaultDomain_3&hash=item3cdb3a4339
A coat of hammerite will see you fine.
One tip on the piston dust cover. Put the seal over the piston but with the part which sits into the caliper hanging off the back of the piston. Then put the lip into the groove of the caliper and push the piston back into the caliper. Easy peasy.
  Clio 2.0 16v 182
Slider pins always seem fine until they aren't serviced properly for a decade.
I removed the seal on this to find the pin had fused to the carrier.
Nyall
  Titanium Ph1 172
Slider pins always seem fine until they aren't serviced properly for a decade. View attachment 123852 I removed the seal on this to find the pin had fused to the carrier.
This is exactly why I ordered new ones.
It's better to have them and not need them.
I suspect my slider pin(s) to have seized up as one of my calipers is binding slightly.
MRBILLYUK
  FF Jeden Osiem Dwa
You want the 7mm bleed nipples , like these . They're a little bit longer than the original bleed nipples and fit both front and rear calipers
http://www.ebay.co.uk/itm/HEL-Stain...pt=UK_Motorcycle_Parts_13&hash=item4ae63d7f28
GrahamS
  335d, GT4
You need an 8mm spanner for them . But they're the M7 x 1.00 nipples , that's for the HEL ones .
These are the ones I bought , but it looks like they're out of stock at the moment .
http://www.ebay.co.uk/itm/4-x-M7-x-1-00mm-Stainless-Steel-Bleed-Nipples-by-HEL-PERFORMANCE-NIP013A-/261485422707?ssPageName=STRK:MEBIDX:IT&_trksid=p2047675.l2557&nma=true&si=KMPOHqqtRvDqAfUDc9nBepYX5HM%3D&orig_cvip=true&rt=nc
I checked my ebay, spot on! I also have the hel ones apparently!
http://www.ebay.co.uk/itm/Stainless...pt=UK_Motorcycle_Parts_13&hash=item2a46c7d115
  Track 172 Cup
I'm also looking at doing a set of calipers I have. I'm gonna strip them and throw them in the engine parts washer and degrease them tonight in work. Are the stainless bleed nipples above correct for replacement of my old ones if I need them?
MRBILLYUK
  FF Jeden Osiem Dwa
Yeah they're the ones you need .
  Clio Trophy
Are the Bigg Red seal kits good quality?
Brakeparts are currently out of seal kits for 3-4 weeks unless I fancy paying £20 for an express order- which I do not funnily enough.
  Clio Trophy
Yes they are.
Good enough for me, cheers.
Can you recommend where to get the front brake hoses? Just looking for standard, no braided lines or any of that.
There are Pagid ones on carparts4less and Mister Auto list quite a few but lengths seem to vary somewhat so not sure what to go for.
Mr Trailer Man
Probably Renault Parts Direct or Renault Wolverhampton.
Not really looked into standard lines tbh.
  Clio 172 Merc ML55
Euro car parts only list one front hose for both of my 172's, one standard and the others a cup for reference @Patrick Bateman. I've used the rear pagid hoses before and they've been fine
Ads
  Clio 182 Trophy. No. 189
After reading this quite fancy doing my calipers.
Out of interest are new calipers stupidly expensive?
